  Foro Ciclismo >> Foro Mountain Bike >> Cual comprar
Creado por donpimpon
03/06/2008 a las 21:17:53
donpimpon
Mayo 2008 | MURCIA
Cual comprar Creado el 03/06/2008 a las 21:17:53
Hola, ayudarme a elegir, las tres son similares pero se diferencian principalmente en la horquilla y los frenos y no se cual es mejor o peor, cual me recomendais?
WHEELER PRO 59 (2007) 500€
Cuadro :Aluminio 6061 Hidrauform Tubes
Horquilla S. :Rock Shox Dart 3 Pop Lock 100m
Direccion :Integrada
Mandos :Shimano Deore 535 Dual Control
Manetas de Freno :Shimano Deore 535 Dual Control
Desviado :Shimano Deore
Cambio :Shimano LX
Frenos D/T :Shimano Deore
Juego Pedalier :Shimano
Bielas :Shimano Deore 442
Cassette :Shimano
Cadena :Shimano CN-HG-73
Pedales :VP-320
Potencia :Wheeler Pro
Manillar :Wheeler Pro
Tija de sillin :Wheeler Pro
Sillin :Wheeler Design 1205 D1
Radios :Stainless 14/15G
Bujes D/T :Shimano 495
Llantas D/T :Alex DP-17 Pair Spoke
Cubiertas D/T :IRC Mibro Marathon 26 x 2,10
Talla :17,5" / 19"
Peso:13,100 kg
Jamis Durango 2.0 2008 460€
FRAME: 7005 triple-butted aluminum main tubes, over-sized seat tube, hydro-formed down tube with integrated gusset, zero-stack head tube, over-sized stays, replaceable derailleur hanger
FORK: RST Omega with magnesium sliders, lockout,30mm stanchions, 100mm travel
HEADSET: TH #11Q, threadless, 1 1/8”
WHEELSET: WTB Speed Disc rims, eyeletted, 32H, Formula disc hubs,14g black stainless steel spokes
TIRES: WTB, MotoRaptor 26”x2.1”
DERAILLEURS: Shimano Deore rear,SR XCR 414, 34.9mm top pull front
SHIFTERS: Shimano Deore RapidFire-SL, 27-speed
CHAIN: KMC Z9000
FREEWHEEL: Sram PG-950, 11-32, 9-S
CRANKSET Shimano Deore M442, Octalink 42/32/22, 170mm (12-15.5”), 175mm (17-21”)
BOTTOM BRACKET: Shimano ES25, sealed cartridge, 68 x 113
PEDALS: Alloy platform with steel outer cage
BRAKESET: Tektro Auriga Comp hydraulic disc brakes with 6” wavy rotor
HANDLEBAR: Jamis alloy riser, 6° sweep x 13mm rise x 620mm wide
STEM: Jamis alloy threadless, 10D rise, 75mm (12- 14”W ), 90mm (14M-15.5”), 100mm (17”),120mm (19-21”) extensions
GRIPS: Kraton for trigger-shift
SEATPOST: Jamis alloy micro-adjust, 31.6 x 350mm, with alloy QR clamp
SADDLE: WTB Speed V Sport SE with SL top and steel rails
SIZES: 12”, 14”, 15.5”,17”, 19”, 21”
COLORS: Sterling Silver/Gloss Black, Gloss Black/Victory Red
WEIGHT: 30.00 lbs.
Kelly´s Madman (2007) 470€
frame: DUALTEC alloy double butted
frame size: 17.5" / 19.5" / 21.5"
fork: MANITOU Slate Comp FFD, 130mm, coil / FFD
head parts: RITCHEY Logic Zero integrated
b.b.parts: TRUVATIV Power Spline
crankset: TRUVATIV ISOflow Power Spline
f/derailleur: SHIMANO Deore LX M581
r/derailleur: SHIMANO Deore LX(07) M581
shifters: SHIMANO Deore SL-M511 Rapidfire Plus
speed: 27
freewheel: SHIMANO CS-HG50-9 (11-34T)
chain: SHIMANO CN-HG53
brakes: HAYES Sole Hydraulic Disc
brake levers: HAYES Sole
hubs: SHIMANO M475 Disc
spokes: stainless steel
rims: KBIX WMX Disc (32h/eyelet)
tires: KBIX 2.0 Nomad - Silica Dual compound
stem: RITCHEY Comp V2 OS
handlebar: RITCHEY Rizer OS(31.8)
grips: VELO D1 ergonomic
seat post: RITCHEY
saddle: KBIX DriveLine PRO-Comp
pedals: VP alloy / steel
accessories: CAT EYE reflector set
weight: kg 13,96 (19.5")
Replicado por xgraciaj
04/06/2008 a las 19:23:26
xgraciaj
Noviembre 2006 | LLEIDA
 Replicado el 04/06/2008 a las 19:23:26
Yo iria a por la Kellys.
Replicado por Jesus17-23
04/06/2008 a las 20:08:44
Jesus17-23
Mayo 2008 | CORDOBA
 Replicado el 04/06/2008 a las 20:08:44
yo creo que la opción más adecuada para mi es la wheeler, aunque la kelly está también muiy bien. te recomendaríaa que miraras las coluer
Replicado por Terali
04/06/2008 a las 20:14:24
Terali
Diciembre 2007 | BARCELONA
 Replicado el 04/06/2008 a las 20:14:24
Ninguna de ellas.
04/06/2008 a las 20:39:06
the chief
Mayo 2007 | SEVILLA
 Replicado el 04/06/2008 a las 20:39:06
Wheeler
Jamis DURANGO 1.0 EN 499 euros
sin duda la Jamis que hay en goodbike es la 1.0 y vien mejor montada que la que tu indicas.
Kellys
Replicado por donpimpon
05/06/2008 a las 17:03:49
donpimpon
Mayo 2008 | MURCIA
 Replicado el 05/06/2008 a las 17:03:49
Gracias por las respuestas, peropor ahora empate
WHEELER 1
kelly´s 1
Jamis 0
La Jamis 1.0 es inferior a la 2.0. (tanto en horquilla como en frenos)
Alguna otra sugerencia
05/06/2008 a las 17:15:04
antonio j
Febrero 2007 | SEVILLA
 Replicado el 05/06/2008 a las 17:15:04
me quedaria con la wheeler
06/06/2008 a las 8:57:07
the chief
Mayo 2007 | SEVILLA
 Replicado el 06/06/2008 a las 8:57:07
06/06/2008 a las 14:33:53
donpimpon
Mayo 2008 | MURCIA
 Replicado el 06/06/2008 a las 14:33:53
La GT tambien la he tenido en cuenta,pedi el precio pero aun no me lo han pasado.
La nueva de 2008 creo que va con rock shox 3 y cambio xt.
Por tanto sera muy similar a la wheeler y en este caso me quedaria la GT si no se dispara de precio.
Alguien sabe el precio y la caractaristicas de la GT avalanche 1.0 2008 en goodbikes.
06/06/2008 a las 18:38:37
the chief
Mayo 2007 | SEVILLA
 Replicado el 06/06/2008 a las 18:38:37
      Cita de donpimpon: La GT tambien la he tenido en cuenta,pedi el precio pero aun no me lo han pasado.
para eso tendrias que mirar en ¿¿??
goodbike.
06/06/2008 a las 20:32:03
Terali
 Replicado el 06/06/2008 a las 20:32:03
Ni la rueda, ni el jamón ni las galletas. ¿Pero no hay marcas de aquí que dan calidad, historia y precio? Para bici hasta 500 Euros: BH y Conor!!
Replicado por julixtr
06/06/2008 a las 21:30:58
julixtr
Agosto 2006 | BARCELONA
 Replicado el 06/06/2008 a las 21:30:58
Yo también apostaría por la GT
      Cita de Terali: Ni la rueda, ni el jamón ni las galletas. ¿Pero no hay marcas de aquí que dan calidad, historia y precio? Para bici hasta 500 Euros: BH y Conor!!
no te falta razón
