Cuadro |
M4 hydroformed tubing, sealed cartridge bearing pivots, disc only, Command Post routing, replaceable deraileur hanger, bolt on cable guides, 120mm travel |
Horquilla |
RockShox Recon Silver TK, Turn Key damper, Solo Air, alloy steerer, rebound adj., disc only, 120mm travel |
Amortiguadores |
RockShox Ario RL, air spring, rebound adj. and LO, 7.875x2.0" |
Llantas |
Custom DT Swiss 445D, disc, double wall, pin joint, eyelets, 24mm, 28/32h |
Bujes |
Specialized Hi Lo disc, QR, 28h. Specialized Hi Lo disc, double sealed cartridge bearing, QR, 32h |
Cubiertas |
Specialized "The Captain" Sport, 60 TPI, wire bead, 26x2.0" |
Bielas |
Shimano FC-M430, Octalink spline, replaceable rings, S: 170mm, others: 175mm. 44A x 32S x 22S |
Cadena |
KMC X9, 9-speed, w/ reuseable Missing Link |
Piñones |
Shimano HG30, 9-speed, 11-34t |
Eje de Pedalier |
Shimano BB-ES25, Octalink spline, cartridge bearing |
Desviador |
Shimano FD-M660 SLX, E-type for DMD, top swing, bottom pull |
Cambio |
Shimano RD-M662 SLX Shadow, long cage |
Manetas de cambio |
Shimano SL-M430 Alivio, 9-speed, trigger |
Manillar |
Specialized XC low-rise, 6061 butted alloy, 680mm wide, 8 degree back sweep, 6 degree up, 31.8mm |
Potencia |
Specialized XC, 3D forged alloy, 4-bolt, 31.8mm clamp, adjustable rise |
Dirección |
1 1/8" upper and lower campy style cartridge bearings for integrated alloy HT |
Frenos |
Tektro Draco, hydralic disc, ceramic pad, Light Wave rotor, |
Manetas de freno |
Tektro Draco hydralic |
Sillín |
Specialized BG Rival, 143mm width |
Tija del sillín |
6061 alloy, 2-bolt micro adjust, setback head, 30.9mm, S/M:350mm, others:400mm
O esta por 950
 TRAIL HUNTER Horquilla ROCK SHOX RECON 140MM Amortiguador FOX FLOAT R BOOST VALVE Cambio SLX Desviador SLX DIRECTO Palancas DEORE Frenos FORMULA RX 180/160 Pal. freno FORMULA RX Cassette SRAM PG950 9V Plato FSA COMET BB INTEGRADO Cadena KMC X9 Potencia TITAN LITE Manillar TITAN LITE RISER Tija TITAN LITE Sillín PROLOGO VERTIGO Puños TITAN BLOQUEABLE Dirección FSA ORBIT ROJO Ruedas MAVIC XM117 / SHIMANO M475 Cubiertas MOUNTAIN KING 2.4 DL/2.2 TR |
