Creado por sabe46
24/08/2008 a las 22:44:07
norco manik vs ns core 1 Creado el 24/08/2008 a las 22:44:07
dentro de poco me voy a comprar una nueva bike y he visto estas dos, de precio y de componentes andan muy parecidas.
lo unico seria que a la norco le tendria que comprar un guia y a la ns un cubrplatos.
norco manik:
frame: 6061 Alloy heavy duty shore inspired tubing and geometry, hydraform DT, milled HT, chainstay yoke
fork:Marzocchi 55 R, 160mm trvl, Rebound
headset:FSA Mallet, chromoly, deep cup
cranks: chainguideTruvativ Hussefelt, 22/32/bash guard, Howitzer Spline BB
pedals:Wellgo LU-A52, sealed bearings, replaceable pins , flat pedal, Orange
chain:KMC Z-9000
casete:SRAM PG-950, 9 speed, 11-34
front changer: SRAM X-7, low clamp, 34.9
rear changer:SRAM SX-7, 9 spd, Medium cage
shifters:SRAM SX-5 trigger, 9 spd
bar: Syncros OE, 2014 aluminum 40mm rise, 31.8mm
stem:Syncros AM stem, 31.8
grips: Pro Palm lock on grips
front brake: Hayes Stroker Ride hydraulic, 8" rotor
rear brake:Hayes Stroker Ride hydraulic, 7" rotor
brake levers: Hayes Stoker Ride
front hub: KT QR-20, sealed bearings
rear hub: Shimano Deore 6 bolt disc
rims: Sun Single Track, pinned, orange
spokes: DT Swiss Champion stainless black 2.0
tires: Kenda Nevegal, 2.35, Stick E Rubber
saddle: Norco Shore, short profile
seatpost: Syncros OE alloy 30.9, 350mm
sizes: XS, S, M, L, XL
NS core 1:
Frame: NS 100% Cro-Mo
Fork: Marzocchi 55R, 140mm Travel, 20mm Axle
Headset: TangeSeiki, loose ball
Stem: NS Quark
Handlebar: NS Habanero
Grips: Velo
Brakes: Avid Juicy 3 185/185
Shifters: SRAM SX4
Rear Derailleur: SRAM X5, medium cage
Bottom Bracket: Truvativ Howitzer 73mm
Crank: Truvativ Ruktion 36T, 170mm, Boxguide XR
Chain: KMC
Cassette: Sram PG-830 8s 11-32
Rims: Sunrims Singletrack SL-1 36H, 26”
Hubs: Joytech Loose Ball 36H, 20mm Front, 10mm Rear
Spokes: Stainless
Tires: Kenda Kinetics 26x2.35
Seatpost: Alloy 27.2
Saddle: Earthworks Rocker
Pedals: Wellgo
Weight: 16,5kg
tambien tenia pensado en cambiarle la horquilla por otra con cambio de recorrido porque quiero algo con cambio de recorrido y habia pensado en la fox 36 talas r del 2007, la rock shox lyric 302. si hay me recomendais alguna otra de este tipo con cambio de recorrido os lo agradeceria
muchas fracias
Replicado por sabe46
24/08/2008 a las 22:48:24
Replicado el 24/08/2008 a las 22:48:24
Cita de sabe46: tambien tenia pensado en cambiarle la horquilla por otra con cambio de recorrido porque quiero algo con cambio de recorrido y habia pensado en la fox 36 talas r del 2007, la rock shox lyric 302. si hay me recomendais alguna otra de este tipo con cambio de recorrido os lo agradeceria |
queria decir rock shox lyric U-turn
< < < < pedaleo big hit
felt y troy lee desings y los lenteja team > > > >
