Creado por CASTANYUT
18/10/2007 a las 23:02:14
Nuevas KTM 2008!! Creado el 18/10/2007 a las 23:02:14
Equipment
Frame: PROWLER 3.0 (862), material: aluminium 6061, 4-bar linkage (PDS), fully adjustable seatpost, sealed grooved ball bearing, head tube for integrated head set
Rear Shock: Man Radium RL, Travel: 150/130, S: Air Spring, D: Platform plus, A: ext. Rebound, Lockout
Fork: Rock Shox Tora 318 u-turn, Travel: 130 - 85, S: Coil Spring, D: Motion Control, A: ext. Reb.& Compression, Lockout, Traveladjust
Rear Derailleur: Shimano Deore XT s, 9-fold, Top Normal - conventionel "Shadow-Design"
Shifting Levers: Shimano Deore, gear lever RapidFire - Two-Way-Release
Front Derailleur: Shimano Deore, Down Swing, Dual Pull
Chain: Shimano HG53, gearchain HG 9-fold Type
Casette Sprockets: Shimano HG50-9 11-34, sprocket cassette 9-fold
Gear Ratio: 11 - 13 - 15 - 17 - 20 - 23 - 26 - 30 - 34
44 - 32 - 22
Crankset: Shimano M521, chain set - Oktalink
Bottom Bracket: Shimano ES25 Oktalink
Brake Levers: Magura Julie disc, aluminium lever
Brake: Magura Julie disc, hydraulic disc brake
Front Hub: Shimano M525 disc 6L, aluminium hub with quick-release, 6-holes mounting
Rear Hub: Shimano M525 disc 6L, aluminium cassettehub with quick-release, 6-holes mounting
Spokes: DT Champion
Rims: Mavic XM-317 disc, aluminium double wall rim 26", with eyelets, 32 holes
Tyres: Schwalbe Nobby Nic 2.25, tyres 26" x 2.25, Black-Skin Evolution, foldable
Head Set: Ritchey Comp A-Head, A-Head Zero-Logic System, integrated, aluminiumspacer
Stem: KTM Smica Comp, A-Head-stem, 8°, 4-screws-clamping D: 31.8
Handle Bar: KTM Satori Comp 640, Lowriser-handle bar, 640mm - 25° Rise
Pedals: VP 528A (KTM), aluminium MTB-pedal
Saddle: Selle Italia XO Trans Am
Seatpost: KTM Smica Comp, aluminium shaft und aluminium clamping - 2 bolts
y la afotoooo en la web KTM
ESPERO VUESTRAS RESPUESTAS, TENGO EL MONO!!!1
Replicado por Pitiklin
18/10/2007 a las 23:44:41
Replicado el 18/10/2007 a las 23:44:41
Si te ha gustado es muy buena compra, aunque también es cierto que la Ghost es otra excelente opción.
Replicado por 111bike
19/10/2007 a las 10:15:34
Replicado el 19/10/2007 a las 10:15:34
Replicado por balloonman
19/10/2007 a las 13:29:25
Replicado el 19/10/2007 a las 13:29:25
Replicado por edugorgori
20/10/2007 a las 12:45:59
Replicado el 20/10/2007 a las 12:45:59
Replicado por PATXIPA
20/10/2007 a las 12:58:18
Replicado el 20/10/2007 a las 12:58:18
Replicado por wacho
20/10/2007 a las 17:46:11
Replicado el 20/10/2007 a las 17:46:11
Me atendio su hija,maja,y entendida en el tema,yo iba a ciegas en esto de las bicis,me recomendo una en stock,la V MAS BIG SHOT,a muy buen precio,aunque se me salia del presupuesto,la chica me dijo q no me arrepentiria,y tenia toda la razon,sino me la hubiera quedado la hubiera cagado.
Bueno a todo esto,la ktm va de cine estoy encantado con ella,y tu sabras como yo q es una muy buena marca de motos,y como no iba a ser de bicis,¿no?.
Replicado por wacho
20/10/2007 a las 22:01:38
Replicado el 20/10/2007 a las 22:01:38
Yo espere dos semanas a q me la trajeran.
Replicado por fguinaldo
26/10/2007 a las 19:00:00
Replicado el 26/10/2007 a las 19:00:00
TEAM LC ELITE de carbono en talla 21.
< < < < bola para el buga
Nueva bici de EROS (ilustre forero) > > > >
