Bueno...una gran duda para una gran elección. Ahí van mis dos opciones posibles ¡dios que lio! A ver qué os parece:
SPECIALIZED ROCK HOPPER PRO 26'(1120 EUROS)
Cuadro: Specialized M4 SL fully manipulated alloy frame, fully butted, integrated HT, forged dropouts w/ replaceable derailleur hanger, disc only
Horquilla: RockShox Recon Gold SL, magnesium lower, 1-1/8" alloy steerer, 32mm alloy stanchions, solo air spring, Pop-Loc remote LO, external rebound adj.
Ruedas: DT-Swiss 445, 26", alloy double wall disc, pinned w/ eyelets
Cubiertas: Specialized The Captain Control, 26x2.0", 60TPI, tubeless ready aramid bead
Cambio: Shimano XT 10sp Shadow Long cage
Desviador: Shimano SLX, 34.9mm clamp, top swing, dual pull
Sistema de Cambio: Shimano SL-M660-10, SLX rapid fire
Bielas: Shimano FC-M552, 2pc., cartridge bearing outboard BB 44A x 32S x 22S replaceable
Cassette: Shimano HG81, 10-speed, 11-34t
Pedales: Alloy 1pc. body and cage, reflector kit, 9/16"
Sillín: Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
Tija de Sillín: Alloy two bolt, 12.5mm offset, micro adjust, 30.9m
Manillar: Butted alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
Potencia: 3D forged alloy, 7 degree rise, 31.8mm clamp
Dirección: Integrated 1-1/8" threadless, Campy type full cartridge bearings
Frenos: Avid Juicy 3 SL hydraulic disc, alloy backed pads, 160mm G2 Clean Sweep Rotor
SCOTT SCALE 50 (1150 EURO)
PESO:11.30 kg / 24.89 lbs
CUADRO: Scott Scale Alloy 6061 Custom butted superlight tubing
D-Forged CNC machined Dropouts
Delta SST bridge / Integrated Headtube
HORQUILLA: Rock Shox Recon Gold TK /Solo Air
Alloy Steerer / Air Spring / Pop Loc Lockout
Rebound adjustable
100 mm travel
DIRECCIÓN:Ritchey OE 1 1/8“
Semi integrated 44/50mm
CAMBIO: Shimano XT / RD-M773 SGS
Shadow Type / 30 Speed
DESVIADOR: Shimano SLX / FC-M660-10 / 34.9mm clamp
MANETAS: Shimano SLX / SL-M660-10 Rapidfire Plus
2 way release / with gear indicator
MANETAS DE FRENO: Shimano BL-M505 Disc
FRENOS: Shimano BR-M505 Disc
180/F and 160/R mm Rotor
BIELAS: Shimano FC-M552 / 2-piece Design
42A x 32A x 24T
PEDALIER: Shimano Cartridge / 68mm shell
MANILLAR: Scott Pilot 18 Team
18mm rise / 640mm
POTENCIA: Scott Comp / 4 bolt
Oversize 31.8mm 1 1/8“ / 6° angle
PEDALES: Wellgo C128
TIJA: Scott Comp / 31.6mm
SILLÍN: Scott Racing
BUJE DELANTERO: Scott Comp Disc CL
BUJE TRASERO: Shimano FH-M595 Disc CL
CADENA: Shimano CN-HG74
CASSETTE: Shimano SLX CS-HG81-10 / 11-36 T
RADIOS: DT Swiss Champion Black 1.8mm
AROS: DT Swiss 445d 32H
NEUMÁTICOS: Schwalbe Rocket Ron 26 x 2.1
67EPI Kevlar Bead / Performance Serie
