  Foro Ciclismo >> Foro Mountain Bike >> TRECK FUEL EX 8 O Specialized Stumpjumper FSR Comp
Creado por PETARDOX
04/02/2010 a las 17:35:53
PETARDOX
Enero 2010 | ALBACETE
TRECK FUEL EX 8 O Specialized Stumpjumper FSR Comp Creado el 04/02/2010 a las 17:35:53
Buenas tardes:
Llevo poco tiempo en el foro, y ahora que quiero cambiarme a una doble, tengo la duda entre estos dos modelos, ambos salen por cerca de 2000 euracos, y no me gustaría equivocarme en la elección, os copio las caracteristicas las dos máquinas a los que no las conozcais:
Specialized fsr comp
CUADRO
Stumpjumper FSR M5 manipulated alloy frame, sealed cartridge bearing pivots, replaceable derailleur hanger, 140mm travel
AMORTIGUADOR
Fox Triad, custom on-the-fly 3-position switch 1) lock out 2) Open 3) ProPedal pedal assisting damping, rebound adj., 7.875x1.9", integrated cartridge bearing yoke mount
HORQUILLA
Fox Float 130 RL, 130mm travel, compression and rebound adj. w/ LO, alloy steerer
POTENCIA
3D forged alloy, adjustable rise, 31.8mm clamp
MANILLAR
Specialized XC low rise bar, butted 7050 alloy, 31.8mm, 660mm wide, 8 degree back sweep, 6 degree up
FRENO DELANTERO
Custom Avid Elixir R SL, alloy backed semi-met pads, S/M: 185mm, L/XL: 200mm rotor
FRENO TRASERO
Custom Avid Elixir R SL, alloy backed semi-met pads, S/M: 160mm, L/XL: 185mm rotor
DESVIADOR
Shimano M660 SLX, DMD, top swing, dual pull
CAMBIO
SRAM X-9, 9-speed, long cage
MANDOS DE CAMBIO
SRAM X-7, aluminum trigger
PEDALIER
Custom Shimano FC-M542, S: 170mm, others: 175mm
LLANTAS
Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
NEUMÁTICO DELANTERO
S-Works Purgatory, 26x2.2", 120 TPI, tubeless ready aramid bead, dual compound
NEUMÁTICO TRASERO
The Captain Control, 26x2.0", 60 TPI, tubeless ready aramid bead, dual compound
CÁMARAS
Ultralight presta valve
SILLÍN
Specialized Format, hollow Cr-Mo rails, SL foam, S/M: 130mm L/XL:143mm
TIJA DE SILLÍN
2014 butted alloy, single bolt setback, 30.9mm
Fuel EX 8™
Juego del cuadro
Tallas 15.5, 17.5, 18.5, 19.5, 21.5"
Cuadro Alpha Red Aluminum w/ABP, Full Floater, magnesium EVO Link, oversized bearings, 120mm travel
Suspensión Delantera Fox Float 130 RL, custom "trail tuned" w/air adjust, rebound, lockout, alloy steerer, 130mm
Amortiguador Fox Float RP2 XV Air Can, custom "trail tuned" w/Pro Pedal, rebound; 7.5x2.0"
Horquilla
Ruedas
Ruedas Bontrager Rhythm wheel system, 28mm, tubeless ready
Cubiertas Bontrager Jones XR w/Kevlar bead, 26x2.2/2.25"; 127 tpi
Transmisión
Manetas de Cambio Shimano SLX SL
Desviador Shimano SLX SL
Cambio Shimano Deore XT "Shadow"
Bielas Shimano SLX M660 44/32/22
Cassette SRAM PG970 11-32, 9 speed
Pedales CrankBrothers Custom Candy C
Componentes
Sillín Bontrager Race w/hollow Cro-Moly rails
Tija de Sillín Bontrager Race, 5mm offset
Manillar Bontrager Race, 40mm rise, 31.8mm
Potencia Bontrager Race Lite, 7 degree, 31.8mm
Dirección VP-A58ACT-TK AHS semi-cartridge
Juego de Frenos Avid Juicy 5, hydraulic disc; 185mm rotors (160mm rear rotor on 15.5, 17.5, 18.5")
En la Specialized me cambian las bielas por unas XT, y ambas me las hacen tubulares,
Me gustaría que me aconsejarais con respecto al amortiguador, si los habeis probado darme vuestra opinión, tambien en cuato a los frenos, y tambien en cuanto si hay diferencia en el peso de ambas. Y todo aquello que se os pueda ocurrir.
Gracias pro anticipado compañeros.
05/02/2010 a las 13:42:33
 Replicado el 05/02/2010 a las 13:42:33
Buenas. Pues entre esas me quedo con la trek, una máquina muy buena y hermosa.
Replicado por hugotopoli
05/02/2010 a las 22:58:42
hugotopoli
Noviembre 2009 | LEON
 Replicado el 05/02/2010 a las 22:58:42
opino lo mismo...
Replicado por becacin
06/02/2010 a las 2:13:00
becacin
Julio 2007 | NAVARRA
 Replicado el 06/02/2010 a las 2:13:00
se llevan el canto un duro,o sea nadaporuqe ya no hay duros........je,je
la mayor diferencia la estetica
los que decis la trek porque motivo???
*yo me quedo con la specialized,sin mas motivo que tengo esa misma y va de maravilla (igual que la trek supongo)
Replicado por charlyduc
06/02/2010 a las 8:17:57
charlyduc
Noviembre 2008 | ZARAGOZA
 Replicado el 06/02/2010 a las 8:17:57
Las diferencia que yo veo, es el amortiguador trasero, y que la specialized monta SRAM y la treck monta shimano, la specialized monta unos elixir y la treck unos avid juiced 5
Replicado por GTvallecas
07/02/2010 a las 19:04:25
GTvallecas
Febrero 2009 | MADRID
 Replicado el 07/02/2010 a las 19:04:25
Sinceramente yo tambien dudaría en cual cogerme, las dos son buenas Marcas, Bicis, Componentes, etc.... pruebalas y las que más te llene.
08/02/2010 a las 22:17:58
 Replicado el 08/02/2010 a las 22:17:58
Buenas. Pues yo, me quedo con la trek, 1º porque me gusta más y 2º porque tengo una trek y 3º porque he escuchadio maravillas del nuevo amortiguador que lleva. Por lo demas las dos son muy buenas máquinas y me encantaria tener una de ellas, o una lapierre x-control 410, o una orbea Ocam, o una BH trail hunter 9.8....
Replicado por ekib0
09/02/2010 a las 1:52:29
ekib0
Julio 2009 | OTROS
 Replicado el 09/02/2010 a las 1:52:29
mira...revisando las especificaciones, la specialized viene con mejores frenos, mejor crankset (con el upgrade que te hacen), cambio trasero mas aguantador, y mas recorrido en el cuadro (140mm vs 120mm)...por esto yo me quedaba con specialized...ahora, si tienes oportunidad de probar ambas sería lo mejor..ya sea en la tienda o con algun amigo que la lleve.
Replicado por cuerna
10/02/2010 a las 20:03:15
cuerna
Febrero 2010 | CANTABRIA
 Replicado el 10/02/2010 a las 20:03:15
yo me quedaria con la trek por que pienso que viene mejor montada y me pareca mas bonita pero eso ya es para gustos.con cualquiera de esas dos makinas te tienes que venir a correr los 10000 del soplao una marcha brutalllllllllllll si no habeis oido  hablar de ella entrr en la pagina de los 10000 del soplao
< < < < holaaa una duda
una de avideos > > > >
